Greetings,
You are on the "bleeding" edge of Detroit. This means, you may see the signals sometimes, others not in the best of conditions.
If possible, post plots at 30 and 50 feet above ground to see if you gain any additional signal from Detroit.
EDIT: if you those trees are in the path of magnetic 240, they will be a problem.
Cheers.
