Old 7-Jan-2011, 5:43 PM   #21
SanDiego_air
With that info it's still hard to determine if your problem is multipath caused by the 2 edge path or a combination of losses and overload in your distribution system.
Have you ever tried connecting the 4220 to a single TV set to see if you can pick up the troublesome stations?
No matter which problem is causing your reception difficulty, your distribution system needed work.
I put together a drawing of my distribution system. I'm not sure what changes I can make that would make a difference. I have made sure to get good quality cable and connectors.
SanDiego_air is offline   Reply With Quote
