Old 13-Apr-2015, 2:55 PM   #4
nate
I will get a picture of the antenna but if a 1970's antenna will not cut it what should we get? The trees sway in the wind so would that be bad to mount it to them? Last time we were up we pointed it in the direction it said to get the signal and we did get it until the sun came out and it warmed up above 40 degrees Fahrenheit. We get others and they come in clear and good. I will check with ksl on all that you asked too. Thanks for all the help
Nate
nate is offline   Reply With Quote
