The stacker is ill-suited for your location since the entire bottom half is useless for your purposes. Skip it.
You have a small TV station showing on your report on the hill just west of your house, KCKS-LD. Can you determine if it's on the air? Virtual channel 26, real channel 25.
A small UHF Yagi would be fine, no preamp needed as you should have plenty of signal.
