Old 12-Apr-2015, 2:34 PM   #9
I thought this was interesting:
https://www.we-energies.com/environm...winddev_qa.htm
Can wind turbines interfere with television and radio reception?
Wind turbines can interfere with television and radio signals received through an antenna. However, given the distances between wind turbines and homes or businesses, the turbines do not interfere with satellite technologies because the signal is received from above rather than from a land-based broadcasting tower.
In the event that signal interference from wind turbines is experienced, We Energies is committed to resolving the issue and covering the costs. We have employed a variety of technologies and techniques in the past to mitigate the issue. For example, at our Blue Sky Green Field Energy Center we have established a program to restore the local channels for those experiencing problems as a result of the turbines. The program includes an evaluation of the resident’s situation and applying the right solution. In some instances, the solution includes servicing an antenna, installing a different antenna or replacing components of the antenna system. If the antenna adjustments do not resolve the matter, the hardware and local programming for satellite service is provided.
There have also been instances where residents have experienced interference with FM radio reception. After evaluation, we have found that a commercially available HD radio is capable of clearing FM reception, and we will work with impacted landowners to provide this equipment.
Regardless of the technologies used to restore television or radio interference caused by our wind turbines, We Energies is committed to providing a remedy for as long as the turbines are operating.
