Old 7-Jan-2011, 5:45 PM   #19
SanDiego_air
I don't know if you aimed the 4220 HD for best signal on UHF and the VHF just happened to fall in place, or a compromise position that picked up the most stations. With a UHF only preamp either antenna should work for you, but the 4220 would be best coupled with a Y5-7-13 VHF antenna and a UVSJ. The HD1080 may not be any better on UHF than the 4220HD, but it will be far better on VHF.
To aim the antenna I had my dad in the roof and me in front of the TV. I tried the antenna 360 deg in small increments and to find the best position for the UHF channels. The VHF channels seem to have no problem in all positions. I plan on trying tilting the antenna 8-10 degrees up to see if I can catch more of the scattering signal.
SanDiego_air is offline   Reply With Quote
