Thread: another newbee
Old 8-Feb-2010, 8:48 AM   #2
mtownsend
Hello and welcome!
Your report does show many channels within reach of a rooftop antenna, but unfortunately, the address lookup was only resolved to a city level. In order to really understand which channels are reachable and which ones are not, it's important to run an analysis for your exact location as best as possible.
If the automatic address lookup is not working for you, you can try using the Interactive Maps feature (link here). After you enter your address, this tool will bring up a map that lets you adjust the location being analyzed. If the automatic lookup came up wrong, you can drag and drop the orange marker to the correct location. You can also switch the map to "satellite" view and zoom in until you can make out the details of individual homes. You can also adjust the value in the antenna height box. Any time you make a change, the list of transmitters below the map will automatically be updated.
When you are satisfied with the location of the orange marker and the antenna height, pressing the "Make Radar Plot" button will create a new radar plot report for you with the current settings. If you post the link for that report back here, we'll get a more accurate reading of your available signals.
