Old 10-Apr-2015, 1:17 AM   #3
zero visual
Do NOT get a pre-amp, you should not need one.
Before suggesting an antenna, please identify the stations that are mandatory.
Also, what is your roof made of and what is outside the roof in the direction of your major broadcast towers
Just moved into a Townhouse, not sure what the roof is made of but will look and see if I can get that answer. The attic is pretty high, depending on the degree it will either have a clear line of site or at 122 degrees looks like 3 additional townhouse attics (we are the 4th one in the line of 6). As far as the channels, I would say Fox, CBS, ABC NBC, CW, PBS but obviously the more the merrier. I just started looking into the DB8e, to help with picking channels in different directions.
zero visual is offline   Reply With Quote
