Old 7-Jan-2011, 5:07 PM   #17
SanDiego_air
The HD 7694P would be a mistake. The HD7694P is a wonderful antenna for someone else, but not you. Your VHF and UHF stations come from two different directions. Your choices are the HD1080 or a combination of two antennas, one VHF and one UHF.
The 4228 HD is a UHF only antenna, but you have VHF stations that you need to receive.
Also, like AD Tech, I find your combative troubleshooting style unpalatable.
I apologize to both you guys. I'm not sure why I'm coming across as combative, but I'm just trying to figure out what is going on and why.
I was trying to look at the specs for CM 4220 (which i currently use) and HD1080 to figure out why HD1080 is better. I can't figure out the difference. any help?
The reason I'm asking more questions for HD-1080 is that AntennaWeb recommends "Blue" type of antenna for me. WineGuard rates the HD1080 up to "Red". http://winegard.com/offair/index.php
Does it matter if I'm going to add a pre-amp anyways?
SanDiego_air is offline   Reply With Quote
