Thanks Rabbit
What I now use are the weather boots, which turn out not to be good enough on terminations at the bottom of a run ( even with a drip loop).
Now I have weather boots "gooped" up with silicone seal from a tube.
One of the links you sent from Summit Seal is what I've been looking for. Thanks again.
Bear
