Old 8-Apr-2015, 1:05 PM   #1
Bigbear
Compression fittings
So I got a compression tool and some Corning-Gilbert RG6 fittings. These are the same as my Direct TV installer used about 10 years ago. These have given me no issues in 10 years. The DTV fittings have some "rubber booties" installed over the threaded portion of the fittings.
Anyone know where I might get some of these? I have been searching the web to no avail.
I would like to try them on my antenna connections as I have issues with water getting in to my OTA setup. At the time I last made them all I had were crimp type F connecters. I covered them with silicone caulk to try to deal with the water. I think they are failing again, so I want to swap them for compression fittings. I do also have some co ax seal that I got after I did the last crimp fittings.
Bigbear is offline   Reply With Quote
