In order to try an attic antenna you've got a couple of facts to consider. ABC is carried on K10KM. The angles between the UHF stations prevent the use of the highest gain antenna. The UHF antenna with high gain and a wide pattern is the DB-4e. The DB-8e can be used if the two panels are aimed in two directions. Next you need a separate VHF antenna. Couple the two antennas in a TVPRAMP-1R. Aim the VHF antenna at60 degrees. The UHF antenna should be aimed partway between the cluster toward the NE and the single station at 105 degrees.
