Old 7-Apr-2015, 7:43 PM   #2
nolens
New to posting on this forum. I mounted a old what I think was a channel master antenna on the roof, using the their mounting hardware for a chimney. When I say old, like twenty or so years old. I found a damaged newer antenna that had a longer UHF end on it. I took that UHF end off the old one and put the newer and longer one on the channel master i put up. I bought a chanelmaster mid level amplifier new. Used RG 6 cable and insulators for connections. Big ground wire. The rotator was purchased used as the one that orginally went with the antenna was shot. It looks to a radio shack deal. I purchased a Channel Master digital converter box. Unreal in the amount of stations picked up with this expensive box, vs a cheap zenith one y neighbor let me borrow. Used channelmaster rotator control, looks like the radio shack one. What is the best way to hook up four antennas to this set up?
nolens is offline   Reply With Quote
