Old 7-Jan-2011, 4:24 PM   #15
SanDiego_air
Seriously, if you're not going to listen to advice from persons in the industry such as TG or myself, just let us know so we can use our time assisting others who do listen.
What do you mean? I am trying your suggestions.
Just using the splitter didn't work.
I ordered the pre-amp and it should get here next week. I'm trying to plan forward in case the pre-amp doesn't work (since my problem is 2Edge signal it sounds like pre-amp might not work).
I had gotten 2 different suggestions for antenna and there was Winegard HD7694P antenna I had found good reviews for. I was just trying to find out if it was appropriate for my situation.
SanDiego_air is offline   Reply With Quote
