Thread: Mountain shadow
Old 7-Apr-2015, 12:24 PM   #2
You need an antenna with as much gain and directivity as possible. An omnidirectional antenna won't work for you.
Start with a 91xg and a TVPRAMP-1R. Aim the antenna at 15 degrees, and then try for a stronger reflection in that general direction. Next, try various heights as low as 18 inches in locations that are clear toward the north. The goal is to find an aim and height that works for as many of the low power stations as possible. Be prepared to permanently mount the antenna at extremely low heights. Next get a VHF antenna for ABC installed in a more normal location and couple it to the UHF antenna using the VHF input of the preamp.
