Old 7-Apr-2015, 11:47 AM   #6
ScottAD
Skip the Mohu Leaf. It's adverting hype far exceeds its actual technical capabilities.
WHICH specific GE antenna model? Where was it mounted? What direction was it aimed? Which specific stations (identify by call letters) were received?
Based on your plot, any reasonably capable antenna, properly installed and connected, with the TV set properly operated, should have received at least 6-8 stations with a likely channel count of around 20 total. Picking up only two suggests that there was fault or error somewhere along the way.
It was the GE 34763 linked here:
http://www.walmart.com/ip/GE-Amplified-Antenna/20976616
The antenna is indoors about 10 ft off the ground, we are on a slope, plus basement. Antenna is facing directly west and I don't recall the stations because I was frustrated
The installation is pretty straightforward so I don't believe there was an error in regards to that. I haven't purchased a new one yet but I did take that one back. With a combination of a Roku, Sling, Prime and a borrowed Netflix we have a lot of content but she wants ABC, CBS and NBC stations not just the news
ScottAD is offline   Reply With Quote
