thanks for the responses, of course there is no way of knowing for sure but do you think i would get away with having the Winegard HD7084P in the attic?
another side questions are you at all familar with the RCA Outdoor Digital HDTV VHF UHF FM Yagi Antenna ANT3036X? would that be comparable to the other two you recommended? i cant find info on if it has a good low and high vhf as you mentioned.
Thanks
