Old 6-Apr-2015, 6:06 PM   #3
WPVI (real CH-6) will be the most challenging signal due to elevated noise / interference in the frequency range that channel uses. I'd go for an antenna that offers quite a bit of gain in the L-VHF range (real CH2 through CH-6). The Winegard HD7084P and Channel Master CM3018 (Advantage 60) come to mind.
Avoid aiming through trees if at all possible.
