Old 2-Apr-2015, 11:26 PM   #2
What results do you get when you run this test? http://forum.tvfool.com/showthread.php?t=13646
Amplification is needed in many situations... but two amplifiers are rarely needed and may produce distortion and noise that reduces reception reliability. By running the test I've suggested, you can determine if the problem lies with the antenna or it placement. Only after proving that the antenna and it's placement is producing reliable reception can we move onto deciding what if any amplification is needed.
