Old 2-Apr-2015, 6:33 PM   #3
srock
Originally Posted by eden View Post
When I was limited to indoor antennas I tried a lot of small ones. The best results I've had, by far, in three locations were with the Antennas Direct C2. Yes, I think the C2V will do better for you. How much is the question. The C2V will pick up strong signals off the back and a small change in direction can make a huge difference on weaker signals. I'd experiment with pointing it both northwest and varying the direction a little at a time and also with pointing it southeast as it will still receive some of the stations to the northwest.
Thanks for the reply.
Do you think positioning near a wall makes any difference? There are no windows but there is a vent on one end of the attic.
Or is the goal to just get it as high as possible then adjust its direction?
srock is offline   Reply With Quote
