Old 2-Apr-2015, 5:25 PM   #2
Jake V
1. Your report shows no height above the ground. Please prepare new versions of your report at the height of your current antenna, 25' and 50' using these instructions: http://forum.tvfool.com/showthread.php?t=14508
2. Please also indicate which set of channels you want (i.e., those to the NNE or those to the South). Also, what is the LOS (visibility) in those directions? Do you have a clear view of the horizon from the antenna or the antenna look through buildings and trees?
3. What direction is your antenna facing? What channels do you get? (List the call sign and not just the network as your report has two of everything.)
