Old 2-Apr-2015, 3:01 AM   #11
siglouie
Scan for channels, then watch TV and observe the results.
Relocate the antenna if necessary, then rinse and repeat (like it says on the shampoo bottle) as needed.
For the most part, my reception is good. However, high-winds, overcast skies, and precipitation, all have a negative effect across the spectrum of channels I typically receive on a clear, windless day.
Channels I 'lose' when issues arise are:
6-WPVI
2-KJWP
69-WFMZ
As mentioned above, reception for these channels is generally good, when the skies are calm and clear. However, even on clear days, I often have to re-scan the Zenith box, to re-acquire the channels, if they're lost.
As I explained previously, using an outdoor antennae is not an option.
Basically, my reception is effected by weather; wind, rain, snow/sleet. On clear days, the reception is good. Simply put, will a different indoor antennae improve reception on days of inclement weather? Perhaps a Multi/Omni directional indoor antennae?
siglouie is offline   Reply With Quote
