Old 1-Apr-2015, 10:22 PM   #1
srock
Mohu Leaf 50 works. Worth upgrading?
TVFool Report: http://www.tvfool.com/?option=com_wr...f1f087840dcda0
I decided to drop my cable TV but I'd love to still get PBS, ABC, NBC, CBS, and FOX.
My first ill-informed attempt actually has surprisingly good results.
Mohu Leaf 50 in a small attic near the air vent. Its about 25 feet above the ground. Its in the south facing (exactly 180 degrees) corner.
Connected to Tivo Romio OTA with 50' RG6 cable.
I have tested with both the Mohu supplied amp and without, no difference at all.
The Green channels in the report all work! 22.1, 2.1, 54.1, 45.1, 54.1 (45 is a bit flaky, but good enough) as well as 2.2, 2.3, 22.2, 22.3, 44.2, 44.3, and 54.2.
My question. Given this setup, would swapping the Leaf 50 for a Sky 60 or a Clearstream 2V be worth attempting to gain at least NBC and CBS? Do not care which market they are coming from.
I can aim an antenna any direction in my attic space but I cannot mount it outside. The attic is not large enough to hold anything much bigger then the Clearstream 2V but I am open to other suggestions.
srock is offline   Reply With Quote
