Old 1-Apr-2015, 10:12 PM   #11
eden
After spending way too much time on my roof today I made the decision to stick with the C2. The DB8e, particularly with the two panels pointed in the same direction, does have more gain. You can't argue with math and physics. However, it doesn't if I separate the panels significantly. The data on the Antennas Direct web site shows that clearly. If I don't separate I lose too many channels. The trade off isn't worth it. Most of the time I get channel 32 (PBS) with the C2 so I guess that will have to be good enough. In my current configuration (C2 + PA18) I can get 11 stations, 33 channels of programming most of the time. I can live with that.
eden is offline   Reply With Quote
