Old 31-Mar-2015, 7:12 PM   #3
snooperloop
Understandable.... Garbage in means garbage out.. Or in this case AMPLIFIED GARBAGE OUT
I really did not want to move it outside but we cannot always have what we want.
The obvious solution is to get the antenna out of the attic.
Your signal power *should* be very strong, but Techshield will have an unmeasured amount of attenuation. Perhaps its only 10 dB on VHF, perhaps its 50+ dB. No one knows for sure.
VHF is HIGHLY susceptible to localized interference from a host of sources that may not be readily apparent. Among these are anything that is solar powered, FM radio stations, electrical and electronics, and power transformers/lines.
If you are indeed encountering some sort of generated interference, then an amplifier will only make it worse.
snooperloop is offline   Reply With Quote
