Old 30-Mar-2015, 12:08 PM   #5
No static at all
No static at all's Avatar
Depending on the amp it may or may not be overloading. The only way to tell is to see what happens without it.
Too bad the OP has disappeared as there is good hope for a successful attic set-up with a bit of tweaking. The biggest issue in the Northern Va area is airplane flutter from large jets landing at the 2 closeby Intl. airports.
