Your current antenna should work fine, but likely just needs some tweaking.
-Are all desired channels except 5 & 9 reliable?
-Have you ever tried running the cable directly to 1 Tuner with the amp completely removed?
-Have you tried moving the antenna around to different spots in the attic. High as possible is usually best.
Reason: Deleted FM trap question-former closeby station has moved to a new location
