Okay, it appears you're 'hooked" around the back side of the hill. Your actual signal levels will be "highly variable" from the calculations due to the methodology of the calculations and your proximity to the hill.
Your best bet, if you must stay at that elevation, would be a Yagi with a tiltable mast mount and a medium gain pre-amp. From our product catalog, I'd suggest the 91XG and the JUICE pre-amp (you're free to get something else, if you wish).
Assuming I've correctly identified you rooftop, your BEST bet, if it's within your means, is to simply take the antenna up the hill behind your house with a 100' cable and gain another 60-75 of elevation which should allow the signals an unimpeded path to your antenna.
