Old 27-Mar-2015, 5:02 PM   #6
There's no middle ground, it either comes in perfectly or not at all.
That is the inherent nature of digital reception. It either works perfectly... or it doesn't.
boost signal strength or otherwise improve reception.
The 'boost' you need would require you to get over the top of that tall building across the street, assuming that my location identification is accurate enough. You cannot reliably amplify that which is barely (or not at all) there.
BTW, I just posted an article in the special topics section that offers an example of your issue. http://forum.tvfool.com/showthread.php?t=15421
