The HBU22 should at least get the UHF channels from Baltimore (ABC, Fox, CW) if aimed more in that direction. If you want NBC 11 & CBS 13 you will likely need to go up to an HBU33 or better yet HBU44.
You might be able find to a sweet spot between DC & Baltimore where you can aim the antenna & get both w/o needing a rotator.
