Tv Antennas and Reception
I suggest a Winegard HD7210P Ghost/multipath killer antenna with No preamp , the forward beam width of this antenna is wide and the antenna rejects signals at the sides and back of the antenna. Point the antenna at about 214 magnetic compass about half way inbetween 40 and 44. And turn the antenna to the left and right for the strongest signals of all the channels in those directions. If you are lucky you will get them all , if not then you will need to use 2 antennas.
