Do you think this is a viable option, or should I look into the Terk HDTVi ?
It's a fairly simple project to test reception using your existing antenna. You may need a new section of coax and an F-81 'barrel connector' for joining the test cable to the antenna coax connector. Both the coax cable and connector are usually stocked in the big box home centers... And they usually have very liberal return policies.
I'd certainly test reception before getting stuck with an antenna that can't deliver worthwhile results.
