I haven't got the mast put up yet so I'm still paying Comcast right now.
The mast is a Rohn 50, but it actually extends only 34'. Then on top of that I have a 16' section that the antennas are mounted on. The top section is on a rotor. The 4228 is at the top of that section, so it should be right about 50'. The 3020 is 5' below the bottom of the 4228, so it will be about 43' high.
I'll be picking up a ladder this weekend so I should be able to test it in a week or so. I really wanted to see if there was anything else I should do before sticking it up in the air.
I have 3 different tv sets, the Samsung and the Sceptre tuners seem to work a lot better than the RCA, they will at least pick up some of the cable channels without a DTA box. The RCA doesn't find anything. I've swapped places for the sets and the problem follows the TV instead of the wiring. I'm hoping the ones with the better tuners will pick up the Knoxville channels. The other one will just have to get by with the Tri-Cities stations.
