Old 25-Mar-2015, 8:46 PM   #7
lrkuta
Assuming that you want to avoid a rotator I'd suggest a 4 bay UHF aimed roughly south plus a medium sized VHF antenna (Y5-7-13) aimed at CBS plus a similar antenna aimed at ABC. Couple the two VHF antennas with a jointenna a for channel 13 and then add the UHF antenna with a UVSJ.
Thank you for your input and yes I do want to avoid using a rotator. You are suggesting a 3 antenna system with jointenna for Ch 13 and a VHF combiner. Any brand of antenna I should use or ones that I should avoid? I currently have an Ebay special that picks up the UHF very well but Ch 7 VHF is spotty and Ch 13 not at all. Any suggestions on the best place to purchase these antennas? What would your go to place be?
lrkuta is offline   Reply With Quote
