Old 22-Mar-2015, 8:32 PM   #1
monkeedu
Help Building New Infrastructure
Hello,
I could use some assistance in making suggestions on appropriate hardware/setup to power an HDTV antenna system for basic channels (ABC, NBC, CBS, etc) at this location:
http://www.tvfool.com/?option=com_wr...f1f0f3c2146f44
The house is down in a valley so I'm concerned about signal strength, whether to use a pre-amp, and if I can still use a distribution amp. I'd like to link up at least 3, possibly up to 5 TVs. There is a current DirectTV mast available for grounding and getting coax back into the house that I would like to make use of, but it is only 6' above the ground. If absolutely necessary, a roof mount may be possible (it would be 30+ feet above the ground).
Any suggestions or help would be most appreciated!
-monkeedu
monkeedu is offline   Reply With Quote
