Old 19-Mar-2015, 6:58 AM   #3
demandzm
Sorry, I was rushed to finish that post and I see now I left out some detail. ill try again.
new report: http://www.tvfool.com/?option=com_wr...f1f00917e13054
thank you for the link
I want to drop my dish so I bought a cheap tv antenna.
This one:
http://www.walmart.com/ip/HDTV-Outdo...Miles/34176799
exactly the same as the lava hd antennas except the elements are a different shape. I bought this because I didn't want to spend $350+ on a proper antenna setup if I wasn't going to get tv stations.
My biggest concern is channel 5.1 so I can get the news. But I would also like to get 12, 9, and 46 if possible. I was able to get channel 5 to come in by pointing my antenna up about 10 degrees. but if I try to get channel 9 now my antenna is pointing towards to ground. this is why I want to know how to tilt the antenna remotely. I realize that a proper antenna might fix this problem.
And finally what antenna setup would you recommend and would my mount work. I would say this is a deep fringe area.
thanks
demandzm is offline   Reply With Quote
