Old 19-Mar-2015, 3:04 AM   #1
demandzm
skew control and picking out new antenna
I just found a fix to my antenna reception problem. All I did was tilt it back about 10 degrees. So now its pointing up a little. Now im picking up 5.1 perfectly. Is there a way I can control this from inside, instead of climbing up on the roof every time I want to change stations.
And next I need a better antenna. right now im using a lava HD antenna. and its junk. my mount is a satellite deck mount bolted to my chimney with a 10' 1-3/8" fence top post bolted in it. ill change mounts if I have to but I cant afford to put up a tower right now.
tvfool report: http://www.tvfool.com/?option=com_wr...f1f0b0b5b6f254
thanks for your help.
demandzm is offline   Reply With Quote
