Old 6-Jan-2011, 10:13 PM   #14
You do not need to spend extra money on quad shielded coax. Black insulation will generally have better UV resistance, so I suggest that when it will be exposed to sunlight.
Rule of thumb, don't use more than one amplifier. You have good to excellent signal levels to begin with so one or the other of those amplifiers will overcome the loss of the splitter. I would try with out an amp, just to see if I could save the money.
I have several HD Homerun tuners, all are the dual tuner model and are in fact two independent HD tuners sharing a case. Each tuner input uses a splitter port.
