I'd back down to an HD7694P which has a bit wider forward beam... Split the aim point between the two groups of signals at 344° and 008° magnetic.
The gain of the antenna should be enough... I'd not buy a preamp or distribution amplifier until I proved the need. http://forum.tvfool.com/showthread.php?t=13646
I realize this is a bit different take on your situation than what I offered back in 2012... I'm older, I'll let others decide if I'm any wiser.
