Old 6-Jan-2011, 9:37 PM   #13
tfrook
What is the difference between the
If you re-use the 8-way splitter (passive I presume), you might need to add a high input preamp such as a Winegard HDP 269.
and the
It sounds like you already own an 8-way splitter. You may or may not need a distribution amplifier ahead of the splitter. For example: http://www.amazon.com/PCT-BI-DIRECTI...4334545&sr=8-5
. Will I only need to use these if a large splitter is used like 8 way? Is the distribution amp the same as the high input preamp?
Also, I noticed that the HD Homerun has two ports for coax, does the antenna have two lines coming off it? Or am I just running the 1 line into my splitter and going from there. I just need to diagram this out.
tfrook is offline   Reply With Quote
