Just fyi, the CA8100 never has been able to pull in ch 2.1 with any reliablity. I really feel that the signal strength of this station should put the station a lot lower on the results page. According to tvfool, it is only broadcasting at 8kw, where all the other stations around me are broadcast at 266 kw to 1000 kw. Channel 18.1 is broadcasting at 30 kw and is 27.4 miles closer to me. Its no wonder why I cant get ch 2.1 in my opinion. Maybe tvfool needs to re-consider ch 2.1 signal strength so it does fall farther down on the NM(db) chart.
