I agree with everything you say, but i have 1 arguement. I have read that the 91xg can pickup the higher vhf bands, but is not rated for them. I can vouch for this as I am receiving ch 18.1 which is broadcast on ch 11. So if I can pulled 18.1 in, why cant I pull in one channel higher, 2.1 on 12? Also, I am pulling in 18.1 with the antenna pointed almost 180 degrees off of the direction 18.1 is broadcast from. SO accually right now I am able to get all the channels I want with just the 91xg, but I am sure the first time the conditions are not just right, I will loose 18.1, which is the channel I watch the most.
But what you suggested will be my solution, so thank you for that.
