Old 15-Mar-2015, 6:48 AM   #3
bjs81
gggrrrrrr .... I did a search on the net after I posted here and found out that what i want to do normally does not work out. If I could just be able to pull in CH 2.1 (cbs), I could leave the antenna pointing in one direction. Instead I have to watch CBS on ch 22.1 from the other direction. I dont understand why I cant get ch 2.1 when it is so high on the list. But it is broadcast on ch 12 and only at 8KW, but then why does it show a signal of NM(db) .3 and I cant get it when I can pull in ch 20.1 that shows a signal of NM(db) -14 ???
bjs81 is offline   Reply With Quote
