Old 13-Mar-2015, 2:29 PM   #1
robertp039
Post Help with my two attenna setup
Hello everyone,
I have done my homework and want to show you guys and gals my plans to see if I am thinking right and get some guidance and advice.
Here are my plans:
Equipment:
1. Antennas
A. Antennas Direct, inc DB8e Extreme Range Multi-Directional Bowtie UHF Antenna
B. Antennas Direct C5 ClearStream 5 High Gain Digital VHF Antenna
http://www.amazon.com/gp/product/B00...A2I7PZX8IWHCAW
http://www.amazon.com/gp/product/B00...=AVFHERP2L596L
2. Pre-Amp
A. Winegard LNA-200 Boost XT Digital HDTV Preamplifier
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
3. Distribution Amplifier
A. Antennas Direct CDA4 4-Way Output TV/CATV Distribution Amplifier
4. Coupler
A. Winegard CC-7870 Antenna Coupler
Setup:
The two antennas (#1 A and B) connect to the Coupler (#4 A) which will combine the two antennas. This will be installed outside.
From the Coupler (#4 A) to the Pre-Amp (#2 A) which will boast the signal. This will be installed outside also.
From the Pre-Amp (#2 A) to the Distribution Amplifier (#3 A) which is inside closer to the TVs.
Here is are signal maps:
http://www.tvfool.com/?option=com_wr...f1f020cd81c23c 28 feet
http://www.tvfool.com/?option=com_wr...f1f0bef55823aa 35 feet
http://www.tvfool.com/?option=com_wr...f1f0ca58807965 50 feet
I am going to install these antennas 28 feet on my roof with J mounts about 3 feet apart from each other.
Any help, ideas, or and advice would be greatly appreciated!!!!!
Last edited by robertp039; 13-Mar-2015 at 3:54 PM. Reason: Fixed signal maps per warning
robertp039 is offline   Reply With Quote
