Old 13-Mar-2015, 6:40 AM   #18
CAchief
If you're trying to remove the reflector panels for bi-directional operation, drill out the rivets, remove the screens, then assemble. To reattach, if necessary, use standard #10 hardware.
A little worried to drill out the rivets in case i have to return it. Can I connect it with zip ties just to see if it work? Set it up per the instructions this morning and was able to pull in all stations I wanted, minus ABC, but only at about 50% signal strength. Added a little more height and lost FOX/CBS but added ABC. This process can be very frustrating! I think I've broken nearly all the tiles on my roof at install area
CAchief is offline   Reply With Quote
