You must assemble it as per the directions except as noted below. The bowties cannot be attached to the crossbar directly without screwing up the antenna.
If you're trying to remove the reflector panels for bi-directional operation, drill out the rivets, remove the screens, then assemble. To reattach, if necessary, use standard #10 hardware.
