Old 12-Mar-2015, 6:17 AM   #4
Moderate sized antennas like the Winegard HD7694P or Antennacraft HBU-33 should offer very good reception if pointed NE and mounted outside. This assumes you can avoid aiming through trees or nearby structures.
To drive a couple of tuners through moderate lengths of coax should be doable without the need of a preamplifier. If you have over 100' of coax and are splitting to many TV's, a distribution amplifier such as the Channel Master CM-3410 can be added between the antenna and splitter after the fact.
