Thanks for the suggestions guys. I have tried to move the antenna a bit, not more than a few degrees horizontally but I will try a few more aggressive adjustments and see if that helps.
It didn't even cross my mind to look at the FM band Tower Guy. I will give the attenuator a shot as well.
The antenna is not far above the roof line, 12" at best. I am limited to the J pipe that came with the antenna right now and I didn't want to screw it through the shingles so I fastened it to the fascia instead. I did forget to mention that I do have some trees in the way as well across my street, I'm sure that's not helping either.
