I'd be considering interference such as FM overload of your TV set. WEXT on 97.7 is 1.8 miles from you on the WYPX tower.
Try a 6 db attenuator before you buy a bigger antenna.
If that does help, unplug everything in your house except your TV set , switch off all unnecessary breakers at the panel and rescan again.
