Old 11-Mar-2015, 10:29 AM   #4
Stereocraig
Originally Posted by freedy View Post
Thanks for that information. It's more or less what I expected to hear but now I'm not just guessing or assuming. My guess is that it is the signal bouncing along the roof because I wasn't having these kinds of fluctuations when it was in the house the prior winter.
Regarding raising the antenna, how much higher are you thinking? I have it on a j-mount installed on the facia at the apex of the roof. Is there a way to add an extension of the type required? From what I've found, taller j-mounts will only get me another 6" or so.
I'm not sure I'd want to go too high w/ one of those, unless you mounted it to some sort of spreader plate.
Directly hitting a rafter, or tie beam w/ at least two of the lag bolts, would be a plus.
